DMF_TomB
- Dec 13, 2008
- Rochester, NY, USA
anybody know of a marker where if you make a mark on a part it adds .0001" thickness to it. that is instead of shimming between parts just making a mark where the ink thickness is .0001"
had a 1 ton part and sitting on 4 supports and probe says one support is .00045" high (.0003" tolerance). i made a sharpie marker mark but didnt seem to do much.
i ended up on high support (6 square inches) marking up with a marker and sanding mark off and it took 3 times to get .00045 down to .0002" (100 grit sandpaper)
i have heard of grinders using a crayon to add thickness instead of shims. just seems a wax crayon would leave a uneven thickness.
using 2 ea .03mm (.0012") shims on one end of part (.0024") and .001 and .0015" on other end (.0025") gives .0001" difference but sometimes you want to use no shims
