50BMG DUDE
Cast Iron
- Jun 17, 2013
- Bonners Ferry
Bought a very nice '08 Doosan MV3016 Fanuc series i control with alpha drives. I need to add a 4th axis table to it (full 4th - not an indexer) I have a Nikken table that will work perfectly with a Fanuc A06B-0313-B031 motor on it. I have a spare M Code relay available in the machine use for clamp/unclamp solenoid.
Can anybody tell me what I need to do to add the drive and interface to the machine? I'm pretty handy with electronics and think I can do it myself. I'm sure I can cable the drive and table assembly, just need to know what to do as far as the control goes. My local Doosan dealer is more interested in selling me a complete new table/drive package and doesn't want to help part out the pieces I need.
So - I need to know
A) What drive should I use that is compatible with the motor/machine setup - Machine has aiSV 80 # A06B-6114-H105 for the Z axis and a H209 for the X/Y axis. I'm pretty sure Doosan uses a smaller drive for the 4th axis though?
B) I believe the C axis is just turned on in the control with a parameter correct? If so which ones? I know I need to set parameters for encoder count, drive ratios etc. I'm willing to pay my local dealer to come out and set this up if I can just get the hardware side lined up.
C) connecting the drive to the controls? I think this is just a fiber optic jumper and wire jumper from the Z axis drive correct?
D) I believe that factory installs normally have a 4th axis ignore switch on the panel for when the table is not installed. This is not a big deal if I can enable/disable with a parameter. The table will normally be in the machine.
Thanks for reading and any help some of you knoweledgable guys can give.
Chris
So - I need to know
Chris
