1/4 -20 tap feed
Community On The Web
Page 1 of 3 123 LastLast
Results 1 to 20 of 47
    Oct 2006
    K. Falls, Oregon
    567
    13
    Post
    Here is a really dumb question. Can some one or better yet would someone tell me the feed on a 1/4-20 tap. I thought is was .05 but the table runs way to fast on a dry cycle. It would break the tap. I am obviously doing something really wrong. I have tapped 10-32 holes with no trouble. Thanks
    Jun 2006
    Melbourne Australia
    538
    139
    30
    Post
    Are you using a canned cycle?
    Oct 2006
    K. Falls, Oregon
    567
    13
    Post
    no
    Aug 2003
    PA
    1,402
    Post
    RPM X thread lead = IPM.
    RAS
    Oct 2006
    K. Falls, Oregon
    567
    13
    Post
    g95f.05z-.5 is the tap forward cycle and it is way to fast.
    Oct 2006
    K. Falls, Oregon
    567
    13
    Post
    Whats the thread lead. 20 or .05
    Aug 2003
    PA
    1,402
    Post
    Lead on a 1/4-20 is .05. Thus, 1,000 RPM X .05=50 IPM. If this isn't a canned threading cycle, are you using a floating holder?
    RAS
    Aug 2003
    PA
    1,402
    Post
    What control is this? I'm familiar with Fadal's g84 for rigid tapping. Both speed and feed are called out in the line invoking g84.
    RAS
    Oct 2006
    K. Falls, Oregon
    567
    13
    Post
    I am using a floating holder.
    Aug 2003
    PA
    1,402
    Post
    What control, and what is G95, according to the manual?
    Ras
  11. #11
    Oct 2006
    K. Falls, Oregon
    567
    13
    Post
    g95 is a machining G code I think IPR instead of IPM. Its a Omniturn controller.
  12. #12
    Aug 2003
    PA
    1,402
    Post
    Found it. Per revolution feed... Actually, the figures are right; it will look fast. However, if your machine does not have a tapping cycle, I think the IPM might work better. You should be running in high range, to enable the spindle to reverse quickly. And, DON'T PROGRAM FOR THE ACTUAL Z DEPTH! Allow for pullout on the holder!
    RAS
  13. #13
    Oct 2006
    K. Falls, Oregon
    567
    13
    Post
    When I threaded 10-32 I programmed g95f.0313 as the feed and it ran awsome. Made 5000 parts without a glich. I thought to find the feed rate I divide 1" by 20 and it would simply give the feed rate. It just doesn't seem to work for 1/4 - 20 now.
  14. #14
    Oct 2006
    K. Falls, Oregon
    567
    13
    Post
    I have a friend that is great with these machines that usually helps me but he is watching football and I didn't want to bother him right now. Hoping to do this without his help.
  15. #15
    Aug 2003
    PA
    1,402
    Post
    Yes, it does. But a 20 pitch thread is much coarser than a 32. It looks fast; at 1000 RPM (speed I run 1/4-20 in aluminum), it looks scary. Keep your finger on the big red button, and try it. Preferably on a piece of scrap first.
    1" divided by pitch is always right.
    RAS
  16. #16
    Oct 2006
    K. Falls, Oregon
    567
    13
    Post
    RAS, I never thought about the pullout on the holder. That means the tap would actually feed in even more then the program allowing for the spindle to reverse right. Might be why I broke some taps in the past. Thanks a bunch.
  17. #17
    Oct 2006
    K. Falls, Oregon
    567
    13
    Post
    WOW, it does look really scary. I'll try it and see. Thanks alot for the help. You guys are life savers for us dumb folk.
  18. #18
    Aug 2003
    PA
    1,402
    Post
    Exactly. On thru holes is not usually a concern, but blind holes will getcha everytime. Measure the pullout on the holder, and program your Z depth accordingly. The best bet in blind holes are thread forming taps; no chip to worry about.
    RAS
  19. #19
    Oct 2006
    K. Falls, Oregon
    567
    13
    Post
    I do have some and I will try them. Thanks alot.
  20. #20
    Aug 2003
    PA
    1,402
    Post
    Let me know how you make out.
    RAS
