Caseman91291
- Oct 31, 2014
Hello there.
My name is Casey and I am a 24 year old graduate of a machinist program here in Minnesota. I recently acquired a mill that came out of a high school. It is a good 'ole Bridgeport R2E4 from 1985. I kinda lucked out because this machine never saw production work. The iron is solid. It's the brains that are lacking. By today's standards it is a little behind in both the hardware and the software electrically speaking. That's not to say that in its day this bad boy couldn't pump out parts but upon testing the machine it doesn't seem to want to chooch like she once did. I am curious and speculating that an excited high school student figured they were a NASA electrical engineer and let the smoke out of her. And as it goes, once that genie is out of the bottle, boy it's tough to put it back.
So I have decided to move ahead and do a retrofit. I have been racking my brain and combing through machinist sites for what everyone else is doing and how to implement it on my project. It seems relatively straight forward. I am reluctant though to take wire cutter to her and gut it. I am not sure I know enough about electronics and programming to grab that tiger by the tail yet. That means any help of any kind is always greatly appreciated.
So, I am thinking I will avoid Linux. That seems to leave Mach3/4 or a commercial kit that would take my lifetime to pay for. Having decided on Mach4 I went hunting for parts. The mill has DC servos that are 128V, sort of odd. I want to keep the high/low gear spindle control and use the variable sheaves and 2 hp AC motor. The trick is that the original controller sent a signal to an air valve to adjust the variable speed pneumatically while a pot let the controller know the position of the sheaves. Getting this to communicate with todays set ups might prove difficult for a simpleton such as myself. The limit switches are 24 volt and should work fine. The power supply are good and can be reused. The lube pump works. So begins the checklist of parts:
DC servo drivers to power X, Y, and Z.
A braking resistor for each to make sure the servo doesn't become a generator and back feed juice.
Then there needs to be a break out board to help pull the brains together.
Smooth step to aid in servo resolution.
A PC to communicate with BOB.
And finally, Mach4 software but I am sure the list with grow when I am elbow deep in this one.
So no problem, hold my beer, I got this. Yeah I wish. My fathers cousin was visiting and he worked in the field of early CNC and automated manufacturing software. This was right up his ally. He looked in the Macgyver era control box and told me it was easy and wouldn't be hard to completely make our own program to run the current components. This intrigued me as it sounded like an opportunity to learn something new. I got all jazzed up about it and then...he flew back to California. So back to the retrofit.
I have had a lot of help from the guys over at CNC4PC. That have the drivers I would need to run these servos. Also just so happen to have everything else I need. They said they would even sell it to me, imagine that. They made up an order for me and and sent it my way. That's were the bump in the road has been. I don't have $1250 to upgrade. I just landed a machinist position here. Also been horse trading and eBay selling to get a little extra cash. But rent and student debt. I don't need to tell you though, everyone has these problems. But if you are lucky and don't happen to have these problems I started a GoFundMe page to ask people for help in the retrofit financially in return for access to the mill and my services upon completion. No pressure, no obligation. Totally up to you. No guns to heads here. You can even just drop a post here with some advice or comments on the build but moving forward I plan to update this thread with the status of the build. Oh yeah, here is the link.
Casey's CNC Mill Conversion by Casey Thrond - GoFundMe
So anyway I got a few photos here of this beauty to show off. You may also notice the tornado of stuff in our shop. We are a farming family and my dad is a bit of a "collector." But whenever I need a part or piece he always seems to have it so the tornado aftermath is actually alright by me and those that visit seeking the same.
