I'm sure this is a simple idea, however I'm not even sure what the terms would be for any kind of "googling" or searching.
I apologize in advance if this is a waste of space.
Basically very new to cnc milling, so...
I'm wanting to mill (engrave) an aluminum plate. The depth of the engraving will be around .2mm (8-10 thou)
This is too close to the nature imperfection in flatness of the work surface to make the engraving uniform. The aluminum is anodized so surfacing wont really work.
It seems a better solution would be to zero z at each engraving feature and have the machine adjust for that.
My questions are: What is this technique called? What tool would accomplish this? Mach 3 or other cheaper software has the feature?
