borne2fly
Hot Rolled
- Feb 7, 2008
- California
I'm still not clear what the difference is between 2.5D and 3D. If I wanted to engrave a circle into an inclined plane, is that a 2.5D or a 3D function?
Here's the definition of a 2.5D part I like best-
If you place the part on a flat table and look down at it from the top, every machined surface on the part is either parallel to the table surface or at 90 degrees to it.
You can have pretty complicated parts that fit this description and thus can be made with 2.5D design tools, they can have pockets, shelves, cutouts, shoulders, ledges, etc., all with arbitrary outlines and still be 2.5D parts.
One thing to keep in mind is that a 2.5D CAM tool will typically generate tool paths that don't limit themselves to 2.5D motion, ie they will use ramped plunging and helical paths when it makes sense, but the final completed part will fit the 2.5D description.
Paul T.
Power Technology
You can doo a lot more than that with a 2.5 mill. You CAN cut in X/Z and Y/Z to create inclines or even rads.
It does NOT have to only be a 2 axis position and then drilling setup.
A 2.5 axis can NOT move all three at the same time. It CAN move ANY 2 at the same time. (May require a G code for "plane designation" to achieve.)
Ox
Then that means a 2.5 D machine can't thread mill, correct???
What about helical interpolation on cleaning out a hole?
I was told that 2.5D could run any two axes in a non-linear manner (say cutting a circle) while the 3rd axis was moving simultaneously but restricted to a linear motion.
Can a 2.5D machine be upgraded to 3D by swapping out some of the electronics, or do the all electronics have to be totally replaced?
Does that mean a simple board swap makes the difference between a 2.5D and a 3D machine? Or do you mean the difference is simply in the software? Or something more?
How does helically interped "cleaning" differ from thread milling? You explain that - and then maybe I can answer that question.
Notice
