Awesome that you are throwing yourself at this all... Great to see that Greg Jackson's original vision turning out to be the "Gateway drug" for a lot of people and serious machines (again and again it seems).
As someone that has done a lot in the horse business over the past 25 years and worked with horses all my life (practically 40 years +) you see "Deal wise" pretty much everything under the sun... Every shade of crookedness you can possibly imagine (lol).
So a VF6 with 50 taper and practically brand new Trunion (BIG one) / barely used on a machine that has 1500 hours over 12 years... That's three weeks a year at 8 hours/day/40 hour week for less than $100K... Brand new base price about $200K probably $230K+ to be useful.
If it seems a bit too good to be true then its usually not. (In the horse trade we say "Easily bought... Hard to keep".)
Normally there's not too much trouble selling a VF6.
Like buying a horse, if this is your first real horse/Haas for keeps (at least for a long while) take someone with you that has at least 25 years of experience of wheeling and dealing older/used Haas machines. (If you can).
It may be a great deal and the machine is in good nick and of a vintage known to be some of the good Haas years maybe?
I'd definitely be skeptical of the 1500 hours(like the other s are saying), but on the other hand maybe it is true and perhaps you should not have posted this on PM forum lest someone beats you to it... (only kidding).
Good luck. Maybe post photos of the machine and maybe some of the Haas aficionados can talk you through stuff "Real time" almost. That might be fun.
P.s. Final note 60" machine with long Haas trunion is not the first thing that would pop into my mind for "Better contouring" (as you say) if you are doing sim 5 versus positional 2+3/3+2.
not 100% clear on what you are after.
Ta
Stupid question... Can you mix titanium and copper chips in a single machine safely ? Might lend credence to the TWO machine concept? At @EriKH what mistakes are you most afraid of? (As you mention it)? What in your eyes would be considered a show-stopper or potential fail that would nearly take you out of the game? (in your opinion?)
Thermite | Military Wiki | Fandom powered by Wikia
There are several different types of thermite reaction... Where copper oxide and freshly cut titanium comes to mind as both "fuel" and oxidizer... Work I have seen with copper tends to make very fine fillings/chips and Titanium when fresh cut has its own "activity" at the surface before it oxidizes. I'm super safety conscious and that's something you might do some research on and how that must be all handled from beginning to end. Maybe I'm being paranoid ;-) .
Copper II thermite reactions are super violent and throwing water on them just makes a bigger explosion. Maybe good to not blow your shop up? Does anyone actively mix titanium, and other metals with copper? [Most of the copper/nuclear work I'm familiar with the guys/shop bought specific and separate machines for doing really high end copper work... Just saying? ]. Not 100% sure why they did that?
Yikes... it's disturbing to consider that I've potentially "lucked out" so far in not having a titanium/copper chip fire on the Tormach. I always use water-based cutting fluid with titanium - perhaps this is what saved me. I am contacting Haas to see what they have to say about mixing chips of the various materials I deal with.
Thank you very much for pointing out this concern!!
My lawyer is also
very skeptical of this transaction and advises careful due diligence. I am under no obligation to pursue the deal, and I don't have the best feeling about it. Nothing good has ever come to me from proceeding in spite of a bad gut feeling, as far as I can recall. Certainly, many bad things have!
In fact, I just contacted the seller, and we agreed to call it off. He didn't seem to mind. If he's legit, he won't have a problem finding another customer, someone else will get a good deal, and that's fine with me.
So, I'm back to square one, and I'm eager to find the best machine for my company. Also, I'm very glad to have you guys on board, this time around.
Budget: approximately $120k
The stuff we most want to make, primarily from titanium:
* guns (but not gun barrels)
* computer components, such as front-panels, hard drive sleds, 120mm fan blades and frames
* hand-tools
* small scale rocket components
* small to mid scale robotics components
* small components for civilian aviation such as yokes, instrument faces, handles. Not engine blocks or propellers.
* single and double-screw compressors
* expensive furniture
* jewel boxes and other small, high-finish luxury items and artistic types of things
Essentials:
* rigidity and spindle power sufficient to keep .01" tolerance at high torque and low RPM for rapidly roughing out large volumes of titanium - without destroying my tooling
* .0005" accuracy and repeatability at 10,000 RPM
* 5-axis working volume sufficient to mill rifle receivers and screws for 10HP compressors on a tombstone
* 2.5D working volume sufficient to mill and engrave 5U 19" rackmount front-panels
* a good reputation for ease of use and reliability
* automatic tool changer
* automatic zero (IE, so I don't need to use my Haimer 3D taster)
Wish list:
* the largest possible 2.5D work volume; 15'x15'x5' would be awesome if it were somehow obtainable given my requirements and budget
* 15krpm spindle with excellent low-speed torque
* sufficient 5-axis rigidity and volume for milling out 21.5" wheel rims (I have the connections to sell these, though doing so doesn't interest me. But, it's an important fallback option)
If I'm looking at a choice between a) staying within budget and meeting my requirements or b) blowing my budget in order to obtain a huge 2.5D working volume and other wish list items, I have to go with (a).
I'm happy to consider any manufacturer, though I have heard a lot of good things about Haas and am inclined to go with them by default.
