Thanks Stan,......... like I said I've been doing a lot of plastic this year - a new ''hook up'' and while like most machinists I've done the odd bit of nylon etc this has been an interesting new experience, and at 55, quite a steep learning curve.
OTOH I found you can get away with ''moves'' on plastic, that with metal would have the workpiece, tool and probably bits of machine whizzing past your ear at great velocity
To run through Stans points, which are aplicable to un filled plastics,....... filled are another ball game entirely.
''I cut some nylon with standard tools. The burr created left another machining operation.''
So did I, and it will . time for a rethink.
''I remembered this guy who said, "When cutting nylon use a 15 degree relief on the tool."
It worked like magic! 16-8 finish. Really!''
It sure does.
''Teflon is maybe even "softer" than Nylon. Try 20 degree relief on the tool. It may cut the Teflon without rubbing the back side of the tool and "Burnishng or stretching" the surface making it longer and hence increasing the bore size.''
20 deg is much better on Teflon, and rubbing tools do effect heat , surface and therefore size
''I'd use the same surface feet, cutting speed, as steel. Because the material can't get rid of the heat of cutting.''
So do I, because it does.
''I don't know if you want any back rake. That might pull the cut in and the size would be unstable there too.''
Careful with back rake, on the harder plastics it'll pull in allright, (just like brass) especially Delrin
Clearance clearance clearance, and sharp sharp sharp are the watch words, did I say sharp?.............. I'm talking as in 8 or 10X glass sharp - look at a ''standard'' cutting tool under a an 8X glass and chances are the edge will look like it's been chewed by a dog.
The smoother the surfaces the chip flows over, the better,............ forget about coated tools, they're not needed and are often not sharp enough.
Threading & tapping the softer plastics, including Teflon is a whole new ball game! and while I don't want to bore the ass off the PMers, if any want to know I'll reply.
Take care,. sharp end to the work.
Sami.
