I guess I am once aggin agginst the grain...
and have decided the best way to go about it will be a spade drill ( carbide Blade ).
I will agree that the spade should make quick work of your hole. But I would not go with the carbide. You would be quite happy with a standard HSS insert.
I will not be able to feed coolant through the drill.
Then your not gunna have a very fullfilling experience.
That would be AMEC.
http://www.alliedmachine.com/default.aspx
You should be able to hold those tols fine with tool holder #25010-003I.
You will need a lot of Z tho. I think that if you take your block out of the vice and set it on the deck you should be fine. The vice may be iffy. (pending on size of machine)
With that toolholder you can git a "rotary coolant adapter". Plumb that ratt into your coolant system via a quick coupling and your in business.
Rec S/F start at 300sfm min and a feed of .017.
The holder that I recomended is spiral flute which will help to auger out your chips. I ran similar in 4140 with maybe 60# coolant with great results.
I would DEFINATELY recommend that you spot that hole! This is a long tool - which is a great advantage to keeping right on size. But should be guided at first.
I was not able to find the drill bodys on the AMEC site.
Also note that this is a #3MT tool. I am sure that a Cat 40 holder will allow the MT shank up inside the spindle zone. (I have some) For whatever reason - this is the only way to git the RCA port assessory.
One more note I guess:
As was mentioned by someone earlier - you doo NOT want to use these as a core drill. One punch - right to size.
HOLD THE PHONE
Just went'n dbl checked my werk and found that I was one line off on my drill body.
You would need a 25020H-004I, or maybe you could git away with a 24020H-003I. These git you into a series #2 insert size (required for 1.047). The -003I/-004I is #3 or #4 MT. You REALLY wunna keep into a #3 if your in a 40 taper machine! (pretty sure)
The 24 tool lists an effective drill depth of 7-3/8, but it's also 8-1/2" to the top of the flute. So I am thinking that you could make it werk. Worst case would be that you git in there and doo some manual grinding to open the top of the flutes for chip evac.
This tool would have a 13-3/4 OAL. Keeping in mind that a cpl inches of that should be above your gauge line. You prolly have 25" of daylight to play with?
Just read last reply:
Feed until the point is thru and about .1 of the shoulder of the spade bit is thru
On longer drill bodies - you want to make sure not to feed the whole insert past the bottom shoulder. It could git cought on the rapid back out and shear off the screws. (Not exactly the end of the werld, but prolly make a mess of your part.)
Think Snow Eh!
Ox
