albatroopa
- Sep 17, 2013
- Canada
Hey guys, a bit of a complicated question here;
i'll start with the machine specs:
mill: bridgeport GX480
controller: fanuc oi-mc
4th axis: hardinge model: ?
I'm trying to get the 4th axis working properly. in the past they've just indicated the 4th axis fixture flat and rebooted the machine. as long as you do a g28 c0. before you turn off the machine and never home it, it's good when you turn it back on.
this has caused several machine crashes, which in turn caused .1deg of backlash in the 4th axis, which due to a bunch of reasons gets aggravated if you try to fix it without fixing the ENTIRE problem, so that's where i am right now. i've already set it to be an incremental dog-search type axis as opposed to whatever it was, and changed the rotational direction to be correct.
i have everything fixed except one thing; the machine position shows up as 360 minus the actual position.
eg:
i turn on the machine and home everything.
i put the fixture in and it's 15.5 degrees off (just as an example)
i use the handwheel and indicate it flat
i go to my work offsets page and go to G54 C section, type in C0. and hit MEASUR. it puts in 344.5 degrees.
the machine position reads 344.5 degrees. everything is good so far.
i go to MDI and put in G00 G90 G54 C0.; and it takes me to 15.5 deg. not good.
i manually change my g54 workshift to 15.5 degrees and everything is fine, but that's not what the machine position reads when it's at that position.
ALSO:
when i use the hand wheel and turn it in the positive direction, the RELATIVE and MACHINE coordinates go down and the ABSOLUTE coordinates go up! (only for the C axis though...)
this issue pre-dates the changes that i've made today.
any idea what's going on here?? i've already spent hours setting this up and getting it this far. as far as I am concerned, it's good enough for ME to use, i'm just worried about the next guy to use it. you guys know everything, so as a last ditch effort, i figured i'd post here. Thanks in advance!
eg:
ALSO:
