scojen
Stainless
- May 21, 2004
- Zellwood, Fl.
OK, so doing the mechanical alignment is pretty straight forward I have done this on several 5 axis routers with Allen Bradley controls it is as easy as do the alignment input the compensation values and your done.
Now I am faced with doing this on a 5 axis router with a Fanuc 15 control essentially the same mechanical process buuuttt what parameters to change values in has me at a loss unfortunately this is a 17 years old Motion Master router and probably one of the few with a Fanuc 15 control and yes Motion Master went belly up more than ten years ago so no help from them.
While I think I have narrowed it down to a given parameter #1220 I am still leery of making any changes just yet. Namely because this machine control has in the neighborhood of 9000 parameters. I do have a parameter manual but like all fanuc manuals it requires some clairvoyance to interpret.
Hopefully one of you has an answer I am looking for @$%%&^* freaking parameters control axis compensation values on this control.
Scott
Scott
