desim
- Apr 23, 2013
- tennessee USA
This is another simple easy item. I searched and did not find a good answer.
I have a job that involves a lot of grooves on a flat plane. The grooves are 90 degrees x 1/4" deep. The material is 3" thick 4140PHT HRc 27-32.
I ask because while we easily do this I think we should be able to do this much faster than we are. What tooling to you recommend for a VMC to install these? We use syn. coolant and have thru spindle cap.
Thanks in advance guys!
