Ukraine Train
Cast Iron
- Feb 10, 2014
- Ohio
I've searched and searched but still confused. I'm running two different parts simultaneously on a Cincinnati Arrow 1500. How do I set the second work offset and invoke it in the program? I selected "active setup #1" on the pendant and located my X0,Y0 on the first part. Now I need to set the location of the second part. Do I do this in the Fixture Offsets table? Or NC Program offset? Then use h1 and h2 in the program to switch between the two?
Also, I'm using the same tools on the two parts but they're at different heights. I'm planning to touch all the tools off the first part then adjust the Z height in the fixture offset accordingly. Is this the proper way to do this?
