Desert Fabworks
- Aug 3, 2012
- Arizona
I have a metal fabrication business and have been wanting to get a CNC router / Mill for a long time. I have been doing research for a few months and spent sometime at a few trade shows looking everything over. I have a lot to learn when it comes to routers and mills, just a little different from plasma.
I decided to start out with a small bench top system and build it up as sort of a DIY project and see how it works and use it for making prototypes, and maybe expand to a larger table down the road.
My goal is to make this a multi-purpose machine if I can. I want to be able to make signs out of wood and plexi, machine parts out of aluminum, cut sheet goods like vinyl and cardboard for prototypes, and if I can attach an extruder and make a 3d printer out of the same machine....
So here goes I have been buying components as time and money allows and finally have enough to get started. I though I would post the build here and hopefully get some good advice along the way and share my trials and tribulations as I go.
So day one got the table from Precision Plasma assembled it and attached the Porter cable 7310 router. I'm waiting on my steppers and controller which I hope will be delivered soon.
