We have a 1" sandvick groover using a vrg125 insert to groove a .125" deep groove. Every machine the bar has been set up on has killed the groove by .03" on the 3rd attempt the operator adjusted his offset -.03" before running and on the rough out hit the tolerance. It seems to me that the boring bar geometry is wrong after having 3 separate machines and operators setting up for this job. Especially since there are 2 milled flats on the bar only leaving 2 ways to set the bar up. As far as the program goes its exactly as it should be as far as size on the rough out and finish.
What could be the reason for having this issue? Any suggestions would be appreciated!
