Tony,
What kind of variation would you estimate on machined top/bottom surfaces, and in comparison, in your experience, how would the Renishaw fare strictly in terms of repeatability?
Thanks.
I'm not sure how you are measuring these things, possibly the details make all the difference. On my DMG with HH glass scales and a Renishaw OMP40-2, if I repeatedly probe a machined surface (moving all axis in between hits) I get a scatter enclosed by about +/- 0.000030. That is moving slowly on the actual probe approach and doing a spindle orient to ensure the same switch and kinematics are in play. If I do a tool change in between hits, generally less than 0.0001, I have seen the occasional outlier at 0.0002 - I presume due to seating the tool holder in some different dirt
If the spindle is oriented for each probe hit, the only inaccuracy for which the probe system itself is responsible is switch accuracy and re-centering, and flight time of the signals to the control. If the flight time is consistent (it may not be in radio or IR schemes) it would be comp'd out in the calibration procedure. If the spindle is not oriented then the polar variation in switching accuracy of the probe comes into play. The machine is responsible for the rest of the inaccuracy: lost motion in measuring system, lost motion in the ways/guides, signal processing time variations. Those will be the same for any probe in the spindle.
When probing at fast speeds, the flight time may become the largest source of error. The Renishaw OMI documentation states that the transmission delay is 144 µs, and an addition 10 µs rise time. It does not state if that is average, maximum, or what the min-max variation is. At 100 in/min probe speed, the axis has moved 0.00026 in that time. If calibrated at the same speed the average might be comp'd out, but the variation appears as measurement error. There are similar variations in control processing time, I have never seen that spec'd. The slower you probe, the less these affect accuracy.
Perhaps everyone already knows these things, in that case Milacron can come in and label me Captain Obvious (again).
