We're running a repeat job where we need to countersink a lot of holes in steel.
We drill the hole 6,9mm, then countersink to a 14,5mm (90°).
Currently we are using a solid carbide TiAlN coated countersink, and get about 5000 holes before the cutting edges are too chipped to use.
Machine is a HAAS VF2-SS, I think with a more stable machine we would see longer tool life, but it's the best we've got.
Is there a good tool that uses some kind of replaceble tips?
I found something in Iscars catalouge for their system with replaceble cutting tips, it only had 2 cutting edges, I wonder if it would chatter or not.
