superrat
- Dec 2, 2006
- kansas city, mo
Hello all, I have an issue that I am chasing my tail on. Here are the specifics:
-Early 90’s Hwacheon lathe with Fanuc O control (Macros enabled)
This is a new program using a bar puller and loop statement to run “X” amount of parts at “X” length.
What happens is the program runs through, loops, pulls and counts all fine until it gets to the end of the program where it jumps to line N201 and should park at machine home. At this point it gives me an “Alarm 510- X overtravel”. If I press RESET and start from line N201 it goes home and all is good and we can start over.
It seems to me that I am inadvertently setting something or not clearing something before trying to execute the G28 U0. W0. but I am unable to locate it at this point. Any thoughts?
To clarify, the machine does not hit hard stop. After RESET I can jog X, clear the alarm and keep going.
I’m pretty green at the whole macro/variable programming, I’m definitely open to improvements.
Thank you.
Program:
O00001
(PROGRAM NAME - 2M SPACERS - PULLER - ALL LENGTHS)
(THIS WILL RUN AND KEEP COUNT OF PARTS RAN)
(START WITH LENGTH OF SPACER +.625 STICKING OUT OF JAWS)
(#500= # OF PARTS TO RUN)
(#501= PART LENGTH)
(#510 IS PART COUNTER ONLY- DO NOT CHANGE )
(#510 RESETS AT M30)
(T0101 WNMG 432)
(T0505 .118 GROOVE)
(T0909 1.0 BORING BAR)
(T0707 1.625 PULLER)
N100 (***PROGRAM MINUS BAR PULLER BELOW HERE***)
G20 G99
( TOOL-1 OFFSET-1 WNMG432 )
G0 T0101
M42
G97 S1000 M03
G0 X1.825 Z.06 M8
G99 G1 X.9325 F.008
G0 Z.16
X1.825
Z.03
G1 X.9325
G0 Z.13
X1.825
Z0.
G1 X.9325
G0 Z.1
( TOOL-1 )
X1.4013
Z.0616
G1 X1.5427 Z-.0092
X1.7481 Z-.1119
X1.8895 Z-.0412
M9
G0 X8. Z 8.
M01
(TOOL - 9 OFFSET - 9)
(1.0 DIA. 2.5 LONG TPG322 INSERT - TNMG-432)
( TOOL-9 )
G0 T0909
G97 S1100 M03
G0 X1.3487 Z.0616 M8
G1 X1.2073 Z-.0092 F.008
X1.125 Z-.0503
Z-[#501+.178]
Z.0
G0 Z.1
M9
G0 X8.Z8.
M01
(TOOL - 5 OFFSET - 5)
(.118 GROOVE TOOL INSERT - GC-4125)
( TOOL-5 OFFSET-5 .118 OD GROOVE )
G0 T0505
G97 S500 M03
G0 X1.825 Z-[#501+.118] M8
G1 X1.6 F.002
X1.61
X1.5
X1.51
X1.4
X1.41
G0 X1.825
Z-[#501+.078]
X1.645
G1 X1.595 Z-[#501+.118]
X1.3
X1.31
X1.2
X1.21
X1.15
X1.16
S250M3
X1.06 F.001
G0 X1.825
M9
G00 X8. Z8.
M01 (END OF PART PROGRAM)
#510= #510 + 1
IF [ #510 EQ #500 ] GOTO201
N101 (***BAR PULL BELOW HERE***)
(BAR PULLER)
G0T0707
M05
X0Z3.
Z-#501
G98Z-[#501+.25]F20.
M69
G98Z-0.062F10.(LEAVES APPROX .050 TO COME OFF FACE)
M68
G0Z3.
X4.Z8.
M01
IF [ #510 LT #500 ] GOTO100
N201
G20 (ADDED TO TRY TO FIX 510 ALARM)
G99 (ADDED TO TRY TO FIX 510 ALARM)
T0500 (ADDED TO TRY TO FIX 510 ALARM)
G28 U0. W0. (ALARMS HERE)
#510= 0
M30
Thank you.
Program:
O00001
(#501= PART LENGTH)
(T0101 WNMG 432)
(T0505 .118 GROOVE)
G20 G99
G0 T0101
M42
G97 S1000 M03
G0 X1.825 Z.06 M8
G99 G1 X.9325 F.008
G0 Z.16
X1.825
Z.03
G1 X.9325
G0 Z.13
X1.825
Z0.
G1 X.9325
G0 Z.1
( TOOL-1 )
X1.4013
Z.0616
G1 X1.5427 Z-.0092
X1.7481 Z-.1119
X1.8895 Z-.0412
M9
G0 X8. Z 8.
M01
( TOOL-9 )
G0 T0909
G97 S1100 M03
X1.125 Z-.0503
Z-[#501+.178]
Z.0
G0 Z.1
M9
G0 X8.Z8.
M01
G0 T0505
G97 S500 M03
G1 X1.6 F.002
X1.61
X1.5
X1.51
X1.4
X1.41
G0 X1.825
Z-[#501+.078]
X1.645
X1.3
X1.31
X1.2
X1.21
X1.15
X1.16
S250M3
X1.06 F.001
G0 X1.825
M9
G00 X8. Z8.
#510= #510 + 1
(BAR PULLER)
G0T0707
M05
X0Z3.
Z-#501
G98Z-[#501+.25]F20.
M69
M68
G0Z3.
X4.Z8.
M01
N201
#510= 0
M30
