aethersix
- May 24, 2016
- New York, USA
I am looking for two cables for an Anilam 3000M. I recently replaced the computer, a faulty 533MHz/128MB board, with an older 233MHz/8MB board. All is working well except I require both the data cable and power cable to interface between the TFT panel and the newly installed computer. The one 40-position connector now needs to the same on both ends. The 5-pin molex for the power has also changed, now requiring a slightly larger connector on the computer side to go from the computer to the inverter. Below are photos of both of them. Finding the proper cables is proving to be quite a task and any help would be greatly appreciated.
40-pin cable: https://i.imgur.com/BYNzvI3.jpg
40-pin / 5-pin LCD interface on computer: https://i.imgur.com/GOK58XR.jpg
40-pin interface on LCD panel: https://i.imgur.com/Zx4w2wv.jpg
Inverter on back of LCD panel: https://i.imgur.com/sdtkPoG.jpg
Required 5-pin molex (pictured is the keypad/keyboard interface cable, incidentally the same connector): https://i.imgur.com/YJ3puzJ.jpg
