CevinMoses
- Jan 30, 2012
- Wisconsin
I have 4 Amada turret presses with Fanuc 6M controls on them. Each one take several 388 mini lamps to light up the buttons to indicate that they are turned on, but the lamps are a pain to replace when they burn out. I am trying to replace them with LED lamps I found through McMaster-Carr, but the lamps don't light up because the polarity of the lighted switch is opposite. With DC power, LED's need the polarity a certain way. I reversed the wiring on all of the buttons (10 I think), but now all of the button lights are on all the time. The illumination circuit of the buttons have 10VDC to ground when not pushed in, and 24VDC when pushed. Obviously I'm getting voltage from somewhere, but without a wiring diagram for this panel, it's a lot of guess work. Just wondering if anyone had tried this before, and if they were able to make it work.
