lpmagruder
- Feb 4, 2014
- Santa Rosa, CA
Hey guys, I'm sure this issue has been discussed before, but I wasn't able to find the right keywords to get any search results...
We have two Haas lathes, an TL30 and ST30, and both use tooling blocks that get internally pressurized with coolant. All our tooling is sandvik with thru-tool coolant, and of course they all have flats on them for the set screws in the tool holder.
What is the best way to block coolant from going through the flats in the tool, and forcing it to only come out of the thru-tool hole? I'm considering welding on something like a woodruff key and turning it down to match the tool OD for a flange at the business end of the tool. I've also considered drilling and NPT tapping the back of the tool and fabricating a hard line.
I'm sure both of these would work but I'd rather not take a production machine down and spend time modifying a tool if there's some solution I can just buy and install.
Thanks.
Thanks.
