Hi Dear All,
I have a backlash problem in X axis on VMC.
I've checked with using dial indicator and found appx 0.5 mm backlash!!!!!
When I programmed (in incremental mode) X+ 0.5 ; X-0.5 ;.....the ball screw was rotating but the pointer on dial indicator was not moving...the exact backlash found 0.55 mm...
Now I am looking to short out this issue and searching for which part to be changed to make this machine run as usual..
