assface421
- May 18, 2016
Hello everyone, it's been a while since posting.
Working on this Craven lathe, I'm the only cnc person here so I am the only one that operates it. They bought it used from Korea about a year ago. Have only done simple jobs here and there, It's just been sitting idle most of the time. I was getting some weird results. When moving from Positive to negative in Z or vice versa, the display on the controller shows .114 movement before I see any movement on the dial indicator I set up. The same thing is happening on the cross slide but only .030. The controller is a GE Fanuc 21I-T. Is there anyway to compensate with a setting in the controller? Any advice?
-Thank you for your time.
