Hello all. I am stumped on this one.
I am turning 6061 aluminum bar stock 1.5" Ive been running the same part for a week or so now with no issues.
I ran out of aluminum, and had a slug of Gr5 titanium laying about so i gave that a shot. Turned down the feeds and speeds, but not enough. The insert drill lost an insert halfway through the hole and pushed the bar back in the chuck about 1/2".
I pulled the Ti out the machine, reloaded the program i was cutting with before {confirmed its the same program} I replaced the inserts in all the tools, except the OD tool in which i just turned the insert to a new edge. Another bar of T6 had come in by this time so i loaded it up and got back to running my part.
Now I'm haunted by surface finish that looks a bit like a golf ball. Kind of faceted if you will. This finish is on both the ID and OD of the part, cut using different tools entirely. Ive changed the inserts, and even changed the entire ID tool.
The parts are coming out on size, but the finish is jacked up.
What is going on here?
Is the machine out of alignment? Did i just get a bar of weird material? I am totally lost right now. Chasing my tail in circles.
