I'm doing a 500pc job that uses 3/4" S7 tool steel, 3" sticking out of the jaws. Final turned diameter is 0.190 and the part length is 2.3". I need .7" to clear the ER16 collet nuts holding the live tools. The 3/4" bar is required for a milled feature that protrudes .330 from the center.
In order to keep chatter down, my SFMs are only 75-200. The further I am from the chuck, the lower the SFM. Also, the part needs sixteen .080" holes drilled in it. I'm feeding at 0.5ipm @ 2000rpm.
The parts are coming out fine, but the low SFM and high material removal requirements are giving me 20 minute cycle times. Also, for some reason, my stainless inserts are working better than my steel inserts.
Any tips on working with S7?
