Rick @G Machine
- Aug 16, 2007
- Wi
It is a 2002 with less than 400 hours. When I set it up i some times notice the x y z load starts jumping around a bit maybe 5% or so. It will sit just fine but if you do a tool change the z will start to act up. If you pull on the vice or tighten a clamp the x and y will start up. For now i have been going to manual jog move the axis that is acting up a few thou and it stops. It acts like its fighting itself to stay still. Anyone else had this problem?
