Captdave
Titanium
- Sep 24, 2006
- Atlanta, GA
We are running a bar job of 1.25" 12L14 in soft jaws and the bar is being pushed back in during the OD roughing process. We were using .075 DOC at .015" per rev and getting push back and have since reduced the feed to .010" per rev and its doing better. During the OD rough the Z axis load is only 10-14% so that isn't much.
We have run this job many times and have not had an issue. Took a skin cut on the soft jaws before we began and set chuck pressure to 300PSI would have some up to .050" short. Blued up the jaws and had excellent contact on the length of the jaw and bar so turned the chuck to max pressure of 370 PSI same result. Bars have oil on them, cleaned a few off and had better results but still random push back. Machined off half of the jaws contact area and that helped a bit more.
May try a sharper edge prep insert on Monday.
