Hello!
May be somebody can help me, I have a Hardinge Talent 8/52 lathe, it has Fanuc 0i-TB control, and recently it started to show BATTERY alarm lighting in yellow on screen,
The main issue is that I already replaced 3 times for new battery and the alarm still continue on the screen, and Im losing parameters everytime when I turn off lathe,
I checked mainboard A16B-3200-0491 with multimeter to check voltage on terminals, traces and everything looks good... battery is 3V
I cleaned board, rechecked again, and alarm still continue, I removed battery with intention, then I turned ON lathe, but there is no effect if it have connected the battery (no matter status of it) it show highlight in yellow "BAT".
May be I need to reset some parameters, to do something on control? I have read that in DGNOS, parameter 202 is which handle this battery ALARM, but all of them are in "0", I was expecting to see "1" which could give me a clue about the issue but no...
I have to load parameters everytime, but the worst part is that everytime i have to "fight" with more alarms that I have to clear...
Any help is so much appreciated!
Thank you
Thank you
