The Machining world is growing at an unbelievable pace. Handheld machines have advanced to highly sophisticated computerized machines (CNC). Similarly, basic 2,3-axis CNC machines have now led on to a more improved, more liked 5-axis CNC machines.
Some benefits of 5-axis CNC machines are:
1. Heightened Accuracy, Efficiency & Cost Effectiveness: Sophisticated Machines
First on our list is, obviously, the points we mentioned before. There is a reason why machinists are fond of this machine type, even with complex process and all. 5-axis machining is the more efficient, accurate and improved of all its counterparts. Owing to less fixturing at multiple operations, using it directly translates to better work-piece quality and durability. This means good parts, less wastage, lower tooling costs, and shorter working duration.
2. Complicated shapes, angles made possible.
With its ability to reach even the most complicated of angles, five-axis machines serve as a savior to all those looking for more complex 4D and 5D parts. Something we would never be able to achieve with your regular 2 axis, 3 axis machines. That too in a single setup, all thanks to its structure which makes it possible to reach out to both sides at one-sitting. All these things translate to better productivity and improved work-piece quality.
Guys, share some other benefits of 5-axis machining.
