Sparky961
Cast Iron
- Jul 10, 2008
- Vancouver Island, BC, Canada
This is an internal feature on a customer part in C180. The sketch is just a simplified area of the entire part for clarity.
The item is run from bar stock and parted when done. I'm removing most of the material with a name brand 14mm brazed carbide drill (because it was handy) then boring the rest with a 3/8" SCLCR boring bar (CCMT insert). I'm taking cautious light and shallow cuts (maybe 0.010"-0.020" DOC and 0.003"/rev ... and just guessing, but maybe 250 SFM or so) because in the past being more aggressive I snapped off the tip of a boring bar after it became wrapped tightly in stringers and jammed at the bottom of the hole.
There are about 100 of them in a batch and this operation is taking close to half the total time. I'm sure this isn't the most optimal way to get it done.
What are some better ways? It has been suggested to me that I step up the boring bar size to 1/2" and push it harder, but that doesn't leave much room for chips to accumulate and/or escape. I'm already looking at getting a solid carbide drill that's on size, and then I don't need to bury the boring bar down the hole. Maybe that's all there is to it?
Thanks for your constructive suggestions.
