Boring head for live tool lathe
Results 1 to 8 of 8
    Feb 2007
    Aberdeen, UK
    2,874
    1025
    979
    Default Boring head for live tool lathe
    Does anyone know of any small boring heads that are easily adaptable to a ER25 live tool?
    Need to bore holes from 12 to 22mm. Tolerances are such that I don't want to use a reamer.
    2µm adjustment preferably.
    Thanks, Gregor
    Dec 2011
    Whitehall, MI
    550
    114
    134
    Last shop I was used Sandvik boring heads. They just held the head in collet I believe.
    Jun 2013
    Oregon
    1,065
    318
    647
    Ouch. Pretty small collet. Circle milling not an option?
    Jun 2006
    Near Seattle
    4,379
    2417
    1081
    Any very fine precision boring head on a straight shank would work, no? But 2micron is very tight, and the head itself will be unwieldly on a turret. I have a big kaiser that might work, I'll look at it when I get to the shop and send a link or model number. (I *think* it's on a straight shank...)
    Jun 2013
    Oregon
    1,065
    318
    647
    Big Kaiser-very good stuff.
    Feb 2017
    AUSTRALIA
    19
    5
    8
    I can confirm the big kaiser boring heads have a straight shank that can be easily mounted in a er25 collet but im not sure what the shank size is but I could check on monday when I get back to work since I have a boring head that does 20mm-25mm but not smaller ones. One issue you might have is the boring head itself is quite short at around 25mm long so you might need to make some sort of extension adapter to hold the head in the collet if your boring deeper or clearance is an issue.
    Nov 2013
    Utah
    2,442
    673
    1295
    Here is a link to the Big Kaiser PDF for small boring heads (pg. 54), they will fit in ER25 with .625 or 16mm shank. 1.3 micron adjustment.
    http://us.bigkaiser.com/pdfs/KAISER%...874946#page=53
    R
  8. Likes HDFanboy, gregormarwick liked this post
  9. #8
    Feb 2007
    Aberdeen, UK
    2,874
    1025
    979
    Thanks all, the Kaiser head the Rob linked is perfect. I normally use D'Andrea and Sandvik heads but in this case I need one that takes a bar instead of a cartridge, and all the D'Andrea/Sandvik ones that fit that requirement won't go in an ER25.
