Pete Deal
Titanium
- Apr 10, 2007
- Morgantown, WV
Early in the year I picked up a used Brother TC-S2A-O. I have been slowly getting it setup and cleaned up. Not much got done this summer due to other projects. This week I took the way covers off and cleaned stuff up. The linear bearings look good and ball screws look good. The y axis ball screw moves about .03" axially when I pull the table back and forth in the y direction. The servo motor mounts to one end of a small cast iron box, the ball screw comes out the other end of the box. I took the cover off the box the coupler that attacheds the ball screw to the servomotor is in there. It appears that coolant got in there. I have not taken anything apart on the ball screw/motor assy. yet other than removing the cover from the box. I think there are a pair of angular contact bearings on the ball screw end of the box to keep the ball screw from moving axially. These may be bad and maybe the coupler is bad, I won't know until I get it apart. I called Yamazen and got a preliminary quote for some bearings. I also have a pdf doc from them that outlines change-out of many major components including the ballscrews. They don't seem to have a good detailed drawing of how all this goes together. One step they say to do is to use an indicator an find the location of the table with respect to the spindle in the y axis in this case and note it. Then during reassembly offset the axis in the control so it shows the same location. This is a little easier said than done since getting an indicator in the spindle, do all the work, and back into the spindle in the same location will not be so easy, at least with the indicators I have. Or do I need to bite the bullet and get the right indicator. Is it a coaxial indicator?
My question is how important is this step for me? Since I have no work offsets or any hard references in the machine yet does this matter? I understand that this is probably a question best asked of a Yamazen tech but it will be after Thanksgiving before I can call them again so I thought maybe someone here would have some insight.
