the.viking
- Sep 20, 2017
Hello. I will be investing in a couple of VMCs to start a small manufacturing unit of my own. I have almost finalized the make and size for the machines. I will be buying an 800 mm and a 1280 mm VMC from BFW (Indo-German collaboration) based on strong local market review and satisfactory service provided by this company.
Following is a quote provided by the company. I am yet to decide on some of the optional parts mentioned here. Please do let me know what all should I order.
I am aware of the need for an individual stabilizer for each VMC. But what do you think of having just one stabilizer for 2 VMCs. This may help lower initial investment but if the stabilizer is down then both the VMCs will also be down.
For the 4th axis rotating table, if I buy one for the 800 mm VMC, can this be used on the 1280 mm VMC? Or is it advisable to buy 2 separate 4th axis rotating tables for each VMC. (Again cost Vs utility)
Thank you and I look forward to your valuable advice.
(Below is a partially censored photo of the quote.)
