Jshawtoolanddie
- Feb 15, 2018
I have a Haas Vf5ss with the renishaw probing system. we use dowel pin holes in our parts to set our work coordinates, due to odd shaped parts. as of now we use one dowel hole to set the coordinates, and another dowel hole to make sure the part is in the correct location based off of measurements when programmed. setting up parts on the mill for remilling takes time because we are having to probe each hole several times and move the part to the correct position. i want to be able to calculate the angle between the first dowel hole stored in g54 and the second dowel hole stored in g55 to plug the angle into g68 and let the machine rotate the coordinates so that i dont have to spend time trying to square the part up. i cant accurately find the angle between the two positions to rotate the coordinates. can anyone help with this issue?
