WILLEO6709
- Nov 6, 2001
- WAPELLO, IA USA
so I have this part I run, 8620 case hardened, masked for case and then later od ground and id threaded/ id finish bored in a final program. The problem is the thread,, there is a bloody index pin hole and the single point threading bars I have get their tips whupped off a little too often, I spend more time screwing with offsets than running that op. so I get a seemingly bright idea... this machine has live tools... threadmill it.
The only problem is I have never used the "polar coordinate interpolation" feature. It all starts good but its going about +1000 times the x movement and -1000 times C axis movement....
as far as thread bars I have tried, Kennametal lt11 laydowns in kc5025, Iscar laydown in IC908, Its a 0.740 min bore with a 16 pitch un.... min 3/4 depth....
Has anybody ever driven a theadmill down the z axis instead of a thread bar? or do I just need some different grade in a multi tooth insert?
Machine is a TC-2L amera seiki from 1996 with a 0-TC, live tools, s20 collet.....
