Techguy
Hot Rolled
- Oct 26, 2007
- Hamburg, MN
I have parts that require a left hand tap but all I have are right hand drills. I do have a left hand centerdrill to use if that will help offset the drill rotation. The tap is a 3/8-32, will I have trouble with such a fine thread tap in aluminum. The machine is a really old chinese benchtop mill I put small stepper motors on and I have a stepper motor for a spindle so I can reverse the spindle. My software is driven by a spreadsheet so programming is easy.
Do you think I can tap at 2500 RPM? The stepper motor says it can go that fast. It says 2.5 amps on the motor so that is 2500 RPM right?
Any help would be appreciated as I have 4000 holes to tap.
I asked Schneider Machine but he wasn't really any help.
Dan
Dan
