Home Page Forums Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Manufacturing Today > CNC Machining
CNC Machining Discuss CNC machines, programing, troubleshooting, retrofits.
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 01-29-2009, 12:21 AM
Titanium
Default Carbide indexable Spot drills
The "regrind" thread prompted me to post a question that I've wanted to post for a while now, and keep forgetting.
Has anyone ever tried using these carbide indexable spot drills? I've only seen a few companies that make them. I think they are Everede, OSG, and some off brand company.
With the price of standard spots and the fact that nobody seems to be decent at regrinding them, I've often wondered of an indexable was a decent way to go. They may vibrate a bit because they are only one flute, but if they work decent, I would think a person could spot your holes pretty fast compared to high speed drills. Anyone?
Bottom of the page here, shows a video of this in action. Looks like a smooth cutting tool, but I'm skeptical
http://www.everede.net/
  #2 (permalink)
Old 01-29-2009, 12:31 AM
Default spot drill
I have been using the osg brand it works very well, we use it to spot,chamfer holes, and machine chamfers on parts,,,,Pete
  #3 (permalink)
Old 01-29-2009, 12:35 AM
exkenna's Avatar
Hot Rolled
Oh man I just saw a new mfg'r for these a couple weeks ago.
I'll see if I can backtrack and get the info for you.
  #4 (permalink)
Old 01-29-2009, 12:38 AM
Titanium
Good to hear, pking. How long do inserts last on those things. Is it fairly cost effective?
Thanks Exkenna, I'll appreciate any info you can get.
  #5 (permalink)
Old 01-29-2009, 12:45 AM
exkenna's Avatar
Hot Rolled
This is interesting:
http://www.youtube.com/watch?v=wO65mdsSC3Y
Made by Mircona in Sweden.
Would it kill ya to go metric?
I'll see if I can get it into the states.
  #6 (permalink)
Old 01-29-2009, 12:52 AM
Titanium
Kill me? No. PITA? Yes. Well, maybe not. I'd have to buy a metric collet I guess to run it in my centers, and metric sleeves to run it in my lathes. Geez, seems like a lot of stuff to buy just to use that spot drill. Doesn't everede make them in english?
  #7 (permalink)
Old 01-29-2009, 12:57 AM
exkenna's Avatar
Hot Rolled
Let me check with a few more sources.
  #8 (permalink)
Old 01-29-2009, 01:09 AM
exkenna's Avatar
Hot Rolled
I just picked up the Ingersoll line.
I think they have something you will like:
http://pdf.directindustry.com/pdf/in...11078-_10.html
Check out the nifty engraving tool, .010 radius on the tip and designed for 100 inches per minute:
http://pdf.directindustry.com/pdf/in...11078-_11.html
  #9 (permalink)
Old 01-29-2009, 01:17 AM
Titanium
Yeah, I've seen that engraving tool in a catalogue that I have. Pretty cool, but Ingersoll seems pretty expensive. On the other hand, it's pretty good quality.
Can you give me a price on the second one from the top with a pak of 10 inserts?
  #10 (permalink)
Old 01-29-2009, 01:26 AM
exkenna's Avatar
Hot Rolled
OK, let me call it in in the morning. My pricing structure is in route, don't have it in front of me right now.
See you guys tomorrow... yawn.
  #11 (permalink)
Old 01-29-2009, 06:23 AM
Titanium
I`ve been using the one from advanced carbide as linked to in post number seven in this thread.
Chamfer mill / spot drill combo?
  #12 (permalink)
Old 01-29-2009, 11:08 AM
Titanium
Mark,
So, what's your consensus? Is it worth it? Do you get a lot of life out of it before it needs inserts?
  #13 (permalink)
Old 01-29-2009, 11:17 AM
Cast Iron
Im sort of interested in these as well. I've got a job that spots a bunch of holes and chamfers to break edges all around some blocks. My only concern is they seem like they would be kind of hard on the spindle on a smaller machine w/one flute and a not so sharp edge as on most inserts.
  #14 (permalink)
Old 01-29-2009, 11:20 AM
Titanium
Kris,
That's my concern too. I'd like to try it, but if I don't like it, it's a lot of money wasted.
  #15 (permalink)
Old 01-29-2009, 12:17 PM
Default SpotIN
Exkenna
I'm very interested in the 140deg version of YB1200006S5RO1 SpotIN series, pg 12. How much do these run?
  #16 (permalink)
Old 01-29-2009, 01:33 PM
Titanium
I bought that tool of Ebay,brand new for about $17 with four tips.It`s a 20mm spot drill.I had to tell them to use it instead of 12mm x 45 deg HSS chamfering cutters.Asked just now about tip life and was told it has done over 1000 1/16" x 45 chamfers on 5/16" holes and spot drilled about 800 holes on two tips.Not very scientific and I don`t suppose it`s crossed the operators mind that a tip that is past spot drilling can still chamfer and vice versa.
I also told someone to order 10 tips for it from our regular guy who comes in every week.That`s not been done either so I don`t know what they cost.
Sorry to be so vague.Will post the model number tomorrow.
  #17 (permalink)
Old 01-29-2009, 02:46 PM
Cast Iron
I know this isn't indexable, and I haven't tried them yet, but I just got an email from Maritool advertising his new spot drills. Prices seem to be pretty good.
  #18 (permalink)
Old 01-29-2009, 02:55 PM
fmari --MariTool-'s Avatar
Stainless
I am currently stocking Chamfer Mills. They are not quite the same as spot drills. Since they are 4 flute carbide the tip is very fragile and does not have too much chip room. They can be used for spotting in soft materials but in alloy steel if you try to spot the tip will chip out. Shortly I plan on stocking spotting drills.
  #19 (permalink)
Old 01-29-2009, 05:24 PM
Curt B's Avatar
I'm glad somebody made use of my suggestion. I found the tip much more durable than the Ingersoll we used previously. We are now spotting and then circle milling the chamfer before drilling on tapped holes since we now have something that holds up.
  #20 (permalink)
Old 01-29-2009, 05:44 PM
PixMan's Avatar
Stainless
I've used these for a few years now, and really like the choices of angle and (most importantly) web thickness at the tip:
http://www.genswiss.com/spotdrills.htm
Genevieve Swiss has been a great vendor for me too.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Ad Management plugin by RedTyger
