Home Page Forums Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Manufacturing Today > CNC Machining
CNC Machining Discuss CNC machines, programing, troubleshooting, retrofits.
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 02-09-2010, 06:19 AM
Default cat40 toolholder with 3/4-16 internal thread
Hello, I am looking for a cat40 toolholder that has a 3/4-16 internal thread to mount an attachment (jig grinder) and cannot find one.
Anyone know of a source for these?
I would also be interested to know if you can buy a generic (soft) cat40 holder
and machine it yourself to your liking?
Thanks, Joe
  #2 (permalink)
Old 02-09-2010, 06:28 AM
Milacron's Avatar
Back when I manufactured tapping machines, we used to take Bilz QC tap chucks that were no. 4 morse taper, turned a groove in the MT shank with carbide on a lathe to get below the case hardening and could then cut at that groove, the MT shank off on a bandsaw to length. The newly exposed "meat in the middle" was not hardened and easy to drill and tap. I should think similar would be possible with CAT holders.
Either that or buy the cheapest Chinese CAT holders you can find as they probably aren't hardened anyway !
  #3 (permalink)
Old 02-09-2010, 06:33 AM
Titanium
Buy a Weldon/Sidelock holder and screw a sleeve on to your attachment.
Example : Buy 1.1/4" holder,make 1.1/4" od x 3/4"x 16 tpi bush.
  #4 (permalink)
Old 02-09-2010, 06:36 AM
Milacron's Avatar
I thought about that but presumed he wanted the least overhang possible (since a jig grinder attachment is typically a rather bulky long thing), such that the ideal might be to cut a CAT holder flush and drill tap from there.
  #5 (permalink)
Old 02-09-2010, 10:06 AM
Titanium
We used to recut tool holders all the time. Milicron is right...once you get under the case it cuts good. Watch crossing screw holes.....
Old holders with worn bores make good custom tools. Flycutters, etc.
  #6 (permalink)
Old 02-09-2010, 12:25 PM
Milacron you are 100% correct with the minimum overhang thing, I already tried alerting an existing cat40 holder but thought it was hard all the way thru.
Perhaps I will take another shot at it.
thanks, Joe
  #7 (permalink)
Old 02-09-2010, 12:28 PM
Milacron's Avatar
"alerting" ? Re hard all the way...possible I suppose but that wouldn't be a good way to make a tool holder as it would be too brittle. Back when we modified tap holders the only company that hardened their tap holders all the way thru was TM Smith. These were also the only tap chucks we ever had trouble with the ends shattering after alot of use. We complained but they refused to change them. Now they are out of business...wonder why...
  #8 (permalink)
Old 02-09-2010, 12:51 PM
Agree with the above suggestions. You'd need an 11/16 hole to chase your thread, but I'd avoid the temptation to start with a 5/8 toolholder because taking .03 per side might not get thru the hard part, and if you happen to hit the transition area and have hard and soft spots, then getting a decent thread will be a real bear. Probably better to start with a 1/2.
If you have to bore and thread across a setscrew hole, you might want to torch anneal a setscrew and loctite it in place first, to get rid of the interruption.
  #9 (permalink)
Old 02-09-2010, 12:57 PM
I've bought blanks from YG1 before, but now I don't see them listed on their web site. You might be able to call a tool vendor and ask about them. This guy sold me one a few years back. Mike Hedwall 1-800-929-3321
  #10 (permalink)
Old 02-09-2010, 01:32 PM
Titanium
I know it's UK but J&L?
Soft cat 40 blanks page 593
Browse the UK Master Catalog
  #11 (permalink)
Old 02-09-2010, 06:14 PM
Smile Thanks!!!!!!!!!!!
Milacron, I meant ALTERING Haa Haa!
Yes indeed I was able to cut into an existing cat40 holder, bore it to .687 and chase a 3/4-16 thread.
Thanks for all the replies, you guys are great!!!!
  #12 (permalink)
Old 02-10-2010, 06:40 AM
Hot Rolled
Jump over to the classified forum. I just bought some nmtb40's dirt cheap.
have fun
i_r_
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Ad Management plugin by RedTyger
