| CNC Machining Discuss CNC machines, programing, troubleshooting, retrofits. |
10-30-2008, 04:08 PM
Cast Iron
Chamfer mill / spot drill combo?
So, I'm trying to make the best use of the limited 10 slots on my tool changer. We're going to be doing a lot of drill/ream and drill/tap and these will take up most slots. Add a face mill, and and end mill and it's full.
Can I use a chamfer mill to chamfer, countersink, and spot drill? Would I want to?
If not, are there other ways to save a few slots on the tool changer for parts with lots of drill ops?
10-30-2008, 04:26 PM
Hot Rolled
I use drill-mills a lot for that. They work great but you do have to be gentle with them if you use them to spot, the points are fragile compared to a real spot drill.
10-30-2008, 04:27 PM
Hot Rolled
Micro 100 solid carbide drill point endmill?
Mike
10-30-2008, 04:32 PM
cant one spot drill will do the work for the drill/ream and drill/tap and countersink? and a chamfer mill to chamfer
-chet
10-30-2008, 04:46 PM
Spot drills do a pretty good job of chamfering edges too.
10-30-2008, 04:49 PM
Hot Rolled
I use the Melin drill mills for spot, chamfer,profile, and drilling. http://www1.mscdirect.com/CGI/N2DRVS...C-T7L391316886
If your trying to make the best of empty pockets try the Kennametal Drill/Ream. (I looked on MSC and didnt see it) call Kennametal. I did a job recently with .2495 holes 1000x in t-100 and didnt have to spot or pre-drill. I was amazed at the performance and not one hole went over.
One of my guys was using this at a previous employer and put us on to it. Best thing I've tried and most of my local distributors carry it.
http://www.advancedcarbidetooling.co...sch_2007_3.pdf
10-30-2008, 05:10 PM
Hot Rolled
Absolutely no question about it: Seco/Carboloy Minimaster.
10-30-2008, 06:51 PM
If your trying to make the best of empty pockets try the Kennametal Drill/Ream. (I looked on MSC and didnt see it) call Kennametal. I did a job recently with .2495 holes 1000x in t-100 and didnt have to spot or pre-drill. I was amazed at the performance and not one hole went over.[/QUOTE]
cant find any thing on the net about Kennametal Drill/Ream?
-chet
10-30-2008, 07:48 PM
Hot Rolled
He may be referring to a Kennametal TX drill, if the workpiece is aluminum or cast iron...it's not for steel or other long-chip materials!
The TX drill is a "bow tie" cross section straight-flute drill; sometimes called a "G-drill" in the automotive manufacturing community.
Mike
10-30-2008, 08:04 PM
I use these on almost everything:
http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=52789751
They're cheap, last a long time, and can be used for both spotting and chamfering. I run mostly aluminum, but they work with steel, as well. You just have to replace them more often.
10-30-2008, 08:20 PM
Hot Rolled
I dont think its the TX. The one I used was a solid carbide through coolant helixed drill, The material was t-100 Armor plate. I ll try to find the container tomorrow.
10-30-2008, 08:33 PM
we use standard spot drills to spot/chamfer all the time just get one with the proper point angle.
10-30-2008, 09:14 PM
We use the Iscar Multi-Master spot drill/chamfer toolsand have good luck in steel. They have a bunch of other style tips available but we have not tried the others. The tip replaces in about 15 seconds and the Z height repeats to less than .001".
http://www.iscar.com/ProductUpdate/P...teDetailID/482
10-31-2008, 02:16 AM
Stainless
My experience (Al and 416) says to use a cobalt spotter for chamfering and countersinking. I use a combined center drill/countersink for centerdrilling. The combinded drill/sink tools have a better geometry and don't break the tip. The spot drills have a .05 flat that tends to break easily, the drill/sink is more robust for spotting in my opinion.
10-31-2008, 07:53 PM
Multi-Purpose Tool
11-01-2008, 05:26 PM
Cast Iron
Thanks for all the suggestions! We'll probably try a couple different ones and find one we're happy with.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Powered by vBulletin® Version 3.8.2 Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
