Houndogforever
Hot Rolled
- Oct 20, 2015
- Boring
Found the reset button on the previous issue and the Fadal is working again. just not perfectly.
New spindle, new idler pulley assy, new spindle pulley.
draw bar pressure is 1550psi.
2 hour run in, multiple times, max temp at nose 74F.
Sounds and runs great.
The part is flimsy, the endmill is extended etc, however, the cut climb milling from X1.25 to X0 sounds fine.
The cut on the opposite side of the part climb milling from X0 to X1.25 squeals like Ned Beatty in a life jacket.
I even reduced the radial depth of cut from .040 to .030 on the X+ movement but it still squeals.
To me, that sounds like a gib adjustment issue, probably needs to be snugged up just a bit as it is shifting in position. Does this make sense or am I looking in the wrong direction?
