I am running an Okuma LS-N 2 turret lathe.
Now what I don't understand is that the turret on the right side (see picture below) has a taper of .015 mm and the turret on the left side has a taper of .055 mm no matter what length I cut at.
I took a piece of scrap to reset the tools because it was down for months waiting for parts.
On the left turret I prorgamed it to take off a .03 mm finish pass at 50 mm in length, it gave me a .055 taper.
"Can you program it out?" - That is what I hear when I mention it.
So I do and then look at the print of the part I have to make so I take the taper out of the program and go half of the distance (25 mm in length) only to have the same exact amount of taper .055 mm.
I put out a long brass bar and proceed to take off a finish pass of .05 mm at a length of 165 mm.
The same exact thing happened - a .055 taper (0 at the beginning and .055 at the end) and I used a dial indicator to check the taper so it wouldn't be a misreading of a micrometer.
What would be the cause of this?
