Bill in PA
Hot Rolled
- Jan 25, 2011
- Fairfield, PA
Hello,
NASA III knee mill, Fagor 8020 control, analog drives, rotary encoders.
Interpolated inside diameters are on size on the x axis, +.007" on the y axis.
Backlash checked with .0005" indicator at the center of the table where the vise is: x axis .000", y axis .000".
Following error is .001" per inch of feed rate. Checked at the following feed rates: 5, 10, 20, 30, 40, 50, 60.
I observe no marks in the machined surface in any of the circle quadrants upon the axis direction change (like one would see when there is a backlash issue).
This problem surfaced suddenly within the last week. I took some time to look at it today. I interpolated a 2" inside diameter and the error would repeat with every cut; with or without cutter comp.
I will find out if the y axis is locating correctly when I put up the next job which requires a bolt circle.
About 2 weeks ago I experience a y axis following error during program execution. It just happened the one time (of course scrapping the part).
I am looking for any ideas of what I can check next.
Thanks much,
Bill
Thanks much,
Bill
