Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Like Tree2Likes
Thread: Cleaning parts after polishing.
    Captdave is online now Stainless
    Sep 2006
    Atlanta, GA
    1,380
    Default Cleaning parts after polishing.
    Have a bunch of Aluminum parts that get some polishing with Scotch Brite after machining and need to clean off the residue before packaging.
    I've tried several spray cleaners but not really getting all the residue off, what do you guys use?
    EDM JOE is offline Aluminum
    Oct 2009
    Tempe, Arizona
    109
    Heated SF-1 ultrasonic cleaning bath, concentrated extra rich (double what the packaging says). Quick dip in tap water to rinse. Shop air hose dries the parts off. I wear disposable Costco nitrile gloves to avoid leaving fingerprints.
    metlcutr55 is offline Aluminum
    Jan 2007
    s w NH
    78
    garage shop viewpoint here. hot soak in simple green mixed per bottle instructions. soon as it cools to handlable temp wipe them. wipe is important, hot soak wont get it all. spray rinse in hot water. air dry while still hot special attn to blind holes. gloves like Joe said if you touch anything else in between.
    kpotter's Avatar
    kpotter is online now Titanium
    Apr 2001
    tucson arizona usa
    3,509
    An ultrasonic will make life so nice, especially if you do this alot.
    gustafson is offline Cast Iron
    Sep 2002
    gloucester ma
    368
    'global aluminum cleaner' from MSC
    use it for cleaning tumbled aluminum parts
    Sep 2006
    Atlanta, GA
    1,380
    Hoped there was some something in a spray bottle that would work for now. Global comes in 5 gallon pails so a little pricey to test to see results.
    Don't have room for a large unit so what is your opinion on this unit?
    380 Watt 1.59 Gallon HEATED ULTRASONIC CLEANER Dental sd6 HB36 | eBay
    metlmunchr is offline Diamond
    Jul 2004
    Asheville NC USA
    7,721
    Anytime I'm using scotchbrite pads on aluminum, I use some warm water and dishwashing liquid (the hand washing type, not the stuff for dishwashers) to do the actual work rather than doing it dry. The finish comes out better and the pad cuts faster and more uniformly because the soap and water solution keeps it from loading up the surface of the pad. Kinda like wet sanding the paint on a car. When finished, rinsing with cold water leaves them clean as can be since the detergent keeps everything in solution and there's no gummy stuff to remove.
    This method also gets rid of any need to wash coolant off the parts prior to using the scotchbrite since you're essentially washing the part clean in the soap/water as you texture the surface.
    I also make some aluminum parts that get fully polished on a buffing wheel using compounds. I've found on those the soap/water and a soft cloth is the best way to clean off the buffing residue without affecting the finish. Any sort of spray and wipe method on those parts will invariably scratch the finish as the residue is dragged across the surface.
    Aluminum cleaners should be approached with caution since a lot of them are chemical brighteners with ingredients that attack the surface in a way you might not expect, or want.
    Murf likes this.
    jrmach is online now Cast Iron
    Jun 2012
    idaho usa
    362
    Parts too big for sink or no sink around,put the gloves on and wipe down with clean terry cloth and lacquer
    thinner.
    Mickey_D's Avatar
    Mickey_D is online now Stainless
    Apr 2006
    Austin, TX
    1,219
    We run almost everything through the tumblers with light detergent and recirculating water. Aluminum parts come out with a very nice even satin finish and only take a quick rinse and wipe down with a micro fiber cloth before they are ready for packaging. We have some parts that are not dimensionally critical that we have cut machining time in half on (cutting out some finishing passes, chamfering, and deburring in the machine operations) and replaced it with a little tumbler time.
    Dualkit is offline Titanium
    Apr 2005
    Beaverdam, Virginia
    3,652
    Tumbling with walnut shells is good for removing most types of residue.
  11. #11
    SPDTool is offline Aluminum
    Feb 2011
    Western Massachusetts
    50
    I use Isopropyl alcohol out of a squirt bottle and a rag...
    Hacksaw116 likes this.
  12. #12
    proturn's Avatar
    proturn is offline Hot Rolled
    Jan 2010
    zimmerman, mn.usa
    655
    Dawn dish soap. Shhh it's my secret weapon........
  13. #13
    CBlair is offline Diamond
    Sep 2002
    Lawrenceville GA USA
    4,003
    Quote Originally Posted by proturn View Post
    I find Dawn cleans well but is harder to remove from the parts, I like Palmolive better...
    Charles
  14. #14
    Sep 2006
    Atlanta, GA
    1,380
    Makes my hands silky smooth...Now that's what I'm talking about
  15. #15
    proturn's Avatar
    Jan 2010
    zimmerman, mn.usa
    655
    Both of you just lost your man cards.....Hand them over
  16. #16
    Jean Solderov is offline Plastic
    Jun 2012
    Portland, OR
    14
    Default S
    Simple Green is bad juju for aluminum.
    We use mild soap and hot water.
  17. #17
    Jan 2007
    s w NH
    78
    Quote Originally Posted by Jean Solderov View Post
    please explain. hundreds and hundreds of 6061 parts washed here with it as i described above. no evidence of juju at all. jmho, ymmv.
  18. #18
    Mickey_D's Avatar
    Apr 2006
    Austin, TX
    1,219
    Simple Green can leave a residue that can leave a splotchy finish on the anodize finish. A heavy acid etch can take it off but it also jacks with fine threads, and I hate to pay for thread plugs. When we switched to tumbling soap from C&M Topline (used to use Simple Green) the finishes came out more even. My annodizer asked if we had switched to a DI water system for washing our parts, but we just do a quick rinse in the break room sink and then dry/blow off the parts.
  19. #19
    Jun 2012
    Portland, OR
    14
    Quote Originally Posted by metlcutr55 View Post
    Prohibited from use on U.S. Military aircraft, as it causes corrosion and undermines the structural integrity of aluminum. There is an alternative SimpleGreen product made specifically for aluminum.
  20. #20
    wrustle is online now Titanium
    Jun 2006
    Massachusetts
    2,029
    We are a supplier to both military and aerospace customers and 95% of our parts are aluminum.
    We have used simple green as a cleaner in our tumblers for years and years, and have never had any issue with any plating, anodizing or chem. film applications, nor have we ever received any documentation forbiding the use of that product from our customers despite shipping thousands of parts over the last 12 years.
    We have so many spec.'s and regualtions to follow regarding the production of those parts, but the use of Simple Green is not one of them and I am curious to know where you got your info from.
    Care to back up that statement with any written proof?
    Later,
    Russ
