.Hello All,
I am new here and to the cnc world.
Can somebody tell me that how long carbide insert last.
For example if i am to turn 7/8" dia shaft down to 5/8" of length about 7".
How many parts should a standard insert make?
Thanks.
Pakistan .. 5/8 dia x 7" .. what are the for?
The answer is 42
Bonus points if you get that reference
i'll see your hitch hiker reference for'
The typical answer is 1 hour, 60 minutes, in use.
BUT..
A high-end insert on a horizontal production machine might make 400 parts.. 1 hr..
a typical insert might make 100 parts on a typical VMC.. 1 hr..
and 20-40 parts over 4-8 hours on a Bridgeport.
All the same, small, steel part.
.First off it is time in the cut not time running so trochoidal is different than others as you are cutting air a lot.
Milling is different than turning as one must account for the number of impacts.
Then there is your labor and machine cost per hour, cost to change tools, and material.
A very, very general rule is 40-60 minutes of actual chip formation time for a normal insert in normal conditions.
One can adjust this by moving feeds and speeds to fit tool changes to break times or shift changes where the productivity loss is lower.
Bob
Notice
