cnc forum posting guidelines
Results 1 to 1 of 1
    Nov 2001
    WAPELLO, IA USA
    6,425
    29
    1814
    Default cnc forum posting guidelines
    I, as cnc forum moderator, figure its about time this place had a sticky at the top. The basic rules to post by in here:
    topics can range anything from cnc machining to production machining of any type,,,,, meaning brown and sharps, broaching, manual dedicated production machines to the lastest 119 axis cnc mill/ lathe/ swiss machine.
    Any titles I deem offensive can and/ or will be locked/ deleted as I see fit
    No option codes will allowed to be posted publicly... I don't need the forum owner getting calls from machine makers complaining.
    I don't mind asking for parameter lists in the event a machine is way old and down,, been in that position myself several times, bad param backup and no real way back up except for posts here.
    Anything that turns into a pi**ing match will also be locked.
    I am fairly easy going for the most part.....play nice and you'll have to look hard to tell that anyone is watching.
