cnc help thread tips - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21
    Jul 2006
    Arizona
    4,403
    17838
    4111
    Quote Originally Posted by 358Mustang View Post
    This persons next two posts from today on other threads say the same thing. I smell a spammer.
  2. Likes yardbird liked this post
  3. #22
    Jun 2016
    RUSSIAN FEDERATION
    Machine tool:Schaublin 60 cnc
    CNC: Sinumerik 810D
    Hello.Got a problem.Sometimes (usually on power on) alarm message appears and blocking machine tool.
    510304: TPC expired - Password Required!
    Hardinge TPC period has expired.
    510305: NV_SYNCH_ACTION Not Executed Error(System)
    Synchronous action program did not complete.
    If anybody knows,can you please answer some silly questions.
    1.What does abbreviation "TPC period" mean?
    2.Why Hardinge ,if machine tool manufacture is Schaublin.
  4. Likes Wild West liked this post
  5. #23
    Aug 2002
    West Unity, Ohio
    23,213
    3517
    6478
    Quote Originally Posted by IL_B View Post
    CNC: Sinumerik 810D
    You should start a new thread - with a title that is related to your specific trouble.
    Example:
    "Schaublin 60 with Siemens 810D - Error"
    Instead of hitting the "reply to thread" button above or below, you need to back up one page to the "CNC Machining" forum page and find the "Post New Thread" button.
    Link to "CNC Machining" page here - LINK
    In the top left hand corner of that page - you will find the "Post new Thread" button.
    Hiding at the bottom of this thread will not likely find the help that you are needing.
    I am ox and I approve this h'yah post!
  6. Likes Philabuster, Wild West liked this post
  7. #24
    Jun 2016
    RUSSIAN FEDERATION
    Thanks,I try.
  8. #25
    Sep 2016
    INDIA
    7
    8
    It generally appears that we see the "dire: machine down: need assistance now" strings, and perpetually there is something to a great degree apropos to the examination that is not in the string.
    Things to be incorporated:
    1. machine producer and sort
    2. year of production
    3. machine model
    4. control brand and model
    5. any apparatus choices/frill in the event that they play into the issue
    6. brand, model, and year of assembling of accessorie the issue is identified with
    The more you put in your underlying string the less another person needs to post to get some information about the machine.
    I'll leave this string open a while, in the event that I overlooked anything post and I'll addit to the rundown
  9. Likes Wild West liked this post
  10. #26
    May 2004
    Vista, CA
    950
    228
    261
    Bottom line that the more information you can give to the person who is trying to help you fix the problem the better. Be sure to be clear.
  11. #27
    Jun 2017
    Alaska
    5
    A debt of gratitude is in order for the majority of this magnificent guidance. It'll truly prove to be useful to dodge long strings to try and attempt to find the issue and pinpoint what should be possible. Welcome it!
  12. #28
    Sep 2017
    Florida
    thanks.. nice work
  13. #29
    Nov 2017
    PAKISTAN
    Default Interact 4 cnc z axis reading problem
    Hello,
    I have cnc bridgeport hiedienhian interact 4 151A
    The problem is the actual workpiece height is 58.3mm and control shows 59.3mm and this error is increase as we go down at height 100mm the error is 101.7mm what is the problem please help me
  14. #30
    Aug 2002
    West Unity, Ohio
    23,213
    3517
    6478
    Quote Originally Posted by Moazam irfan View Post
    Hello,
    Bad encoder?
    Think Snow Eh!
    Ox
  15. #31
    Mar 2018
    INDIA
    Default Help in setting up a robot / router
    HELP IN SETTING UP A ROBOT / ROUTER
    Hello everyone,
    I am new to this forum and CNC world.
    I have a small scale parts factory and we make custom body parts for automobiles. I am always looking out to make products precise and better quality.
    I am looking for suggestions on making an all-purpose robot (since I can not afford separate robots and we will not be using it regularly) which can fit a waterjet cutting head to cut 4mm fiberglass parts and metal, laser cutting head to cut 2-3mm MS/SS/aluminum sheets, tig welding torch (not necessary), milling tool for wooden/foam patterns and 3D printing in plastic for patterns with work area approximately 1 cubic meter or more. If everything is not possible or proves to be very expensive, only milling and laser cutting heads will be ok for me as these will be used regularly.
    Or if I can do this with a CNC router, let me know what will be the best options for me. 5 Axis minimum is required for my products.
    Please let me know which will be the most economical robot for our purpose and head attachments for different work mentioned above. Where can I find used machines and used heads? What do I need to check for before buying a robot? What all comes with the machine?
    I can find a CNC operator here in India who can operate the machine.
    I'd be very grateful for any suggestions and help.
    Looking forward for reply.
    Thank you and Best Wishes from India
  16. #32
    May 2007
    1,376
    2066
    247
    Add Machine level check possibly it is a very important fundamental.
  17. #33
    May 2018
    New York
    Thanks for all of this awesome advice. Appreciate it!
  18. #34
    Jun 2004
    Melbourne Australia
    5,199
    Quote Originally Posted by richardanmmol View Post
    I'd lay odd's you turn out to be a spammer?
