Last night the night shift ran our Doosan 400 and didn't check the coolant levels. They ended up running it dry. This morning we turned on the flood coolant and nothing was coming out. The through spindle coolant works but it is a separate pump.
We checked all the filters and when we took off the cover to the coolant tank and turned on the flood coolant we see the coolant in the tank moving around, so it's doing something.
We are thinking that perhaps the pump needs to be primed because air got in the system. But I find it hard to believe that they need to be primed. I looked in all of our manuals and scoured the web to no avail.
So do you guys know if these pumps do need to be primed? If so how do you do it?
Any suggestions as to what else could be causing the problem?
