You'd be hard-pressed to find a mill that could hold six tenths over 4 quadrants. The above idea wrt going in with a boring tool and not worrying about milling in the x/y plane. Skimming is difficult- if the cut doesn't load the insert it wants to rub and deflect the holder. You have a method to gauge this bore?
Edit: 90 mm? In what universe is this a "large" hole? The only reason I clicked on this thread was because you mentioned milling a large hole. 90 cm would have been 35", an actual decent-sized bore.
NX-CAM,
As other have mentioned, 90mm is not a large hole. Also, are you wanting to hold *size* to ±15µm or roundness to ±15µm or both? Regarding the 25mm depth, is it the 25mm you are wanting to hold to ±15µm, or the bore being straight within ±15µm?
That said, A machine that can hold 15µm on a 90mm bore should also be able to hold that on a considerably larger hole (though other issues like temperature control and how the part is held will probably influence a larger part to a much greater degree).
Is it possible? Of course. How much would you like to spend to accomplish that? Those numbers could probably be held on a Haas or Fanuc or a number of machines on an aluminum or mild steel part. Jump up to something harder, or maybe Inconel or titanium, and now there's a decent chance that a lot stiffer machine is required, especially if you want to do it in production day after day.
As with many questions posted here, the more specific and detailed you can be with your question(s), the easier it is for the participants in this group to answer your questions.
PM
What is large to some is small to others. Some people work on stuff that is very tiny, some people work on stuff that is very large.Dia 90±15µm mm is NOT a large hole !? TO MILL !?
.It is possible to Mill a Large Diameter Hole with high precision of +-0.015 (mm) ?
For example for a Bearing Pocket : Dia 90 +-0.015 depth 25 !
For about this precision (if possible), what would be the max acceptable diameter ?
means.Department 25±.1
Is A Perpendicular to B? Is A a straight line, a hole, a chamfer, a pitch diameter, is B a figment of some ME's imagination? What do you think, every print has the same Datums?
But no I do not understand what means.
I'm trying to help you get a real answer my friend. I do in fact understand. So to answer your question; Yes!!
R
I do not believe that this is an appropriate behavior here.
I have 15 years of working with GD&T
Dia Position to A B mean in this case, Dia is perpendicular to A and Concentric to B
I was refering to depth
And you do not have to answer, if you do not understand, please do not answer
Notice
