1996 vintage Accurpress control. Owners think the monitor may have been color before it went to amber only*. The 6 wires at the connector hint that it probably was. (R,G,B,H,V,G is the usual minimum for color monitor wires) I've never seen a color monitor go from color to monochrome like this before however...have you ? Bottom line is, as you can see from photo the monitor still works but it's too bright and with some strange horizontal lines, so it may go out completely any day. I adjusted the brightness and contrast pots and it made no difference whatsoever.
Naturally the control maker wants an outrageous sum for replacement and the user can't spare the downtime to have it fixed. The ideal would be to know if for sure it is getting color signals and what exactly is the H (horizontal) frequency so it could be replaced with LCD.
If it was in my shop I could tell with a frequency meter but it's 50 miles away and not my machine.
*(on edit) I just Googled Accurpress control, images and found only two images of the same control. Both of them have monochrome amber displays. This indicates the owners are probably having a false memory of how it used to be. Then again, why would a monochrome monitor have 6 signal wires ?? I wonder if it's like many controls in the mid 90's where the monitor is monochrome but the control is supplying color signals for either an optional color monitor or the color monitor that would be standard the very next year ? I have had Bridgeport CNC mills for example with monochrome monitor but when replaced with color LCD they did display in colors and looked quite nice.
