CNC Power Chuck with bad jaw lift, can it be repaired?
Results 1 to 4 of 4
    Mar 2003
    Utah
    1,057
    51
    15
    Default CNC Power Chuck with bad jaw lift, can it be repaired?
    Hello
    I'm using a Haas ST-30 with LMC PC-10-78-01 10" power chuck. The chuck jaw lifts about .005" at clamping pressure of 150 p.s.i. The movement is clearly visible in the master jaw / chuck body interface.
    Replace or repair? Is it possible to repair them?
    Jul 2009
    Peoria, IL
    11,022
    41
    8310
    I've never heard of anyone repairing them. The only way you could really do it is to grind the chuck body and make new masters with smaller grooves. By the time you do that, you could probably buy a new chuck.
    FWIW, .005 doesn't seem too bad to me.
  3. Likes apestate liked this post
    Mar 2003
    Utah
    1,057
    51
    15
    I don't know. Seeing the master jaw move .005" when clamping at low pressure makes me think hard jaws and collet pads are a no-go on this lathe.
    Oct 2005
    9,837
    16969
    5068
    IIRC Worldwide Chuck in Ohio does repairs, they chrome and re-grind.
